Dumb gear lever question
Keny73tj
Bike owned: Cagiva Mito, FZR 4003TJ
Post by Keny73tj »
Dumb question I know but how does the rod come off the gear lever is there a circling or does it just pull off somehow? I've tried pulling it but don't want to break it (I can be a bit ham fisted)
Thanks in advance
Cheers Retarded
bikemonkey
Re: Dumb gear lever question
Post by bikemonkey »
It should twist off. Undo the two locking nuts at each end and rotate the bar, one end is a right thread and one end a left thread, so it'll either do up or undo both ends at the same time.
That's what the NC30 one does anyway, I think it's the same.
tigerclaw
Post by tigerclaw »
I think you mean the ball and socket section of the link - I think its press fitted because I gave up on it - worrying I would break mine too
Keny73tj
Post by Keny73tj »
I'm sure someone will enlighten us soon! I bet Boris will be first in;)
Post by Evilchicken0 »
The easiest way to take the gear hang off is at shaft. Mark the shaft end and gear change so you know where to put it back on. Undo and remove the pinch bolt and then tap a flat blade screwdriver in to open it up. Jiggle the gear change off keeping it level or it will bind onto the shaft.
To adjust the angle of the pedal undo both the locknuts on the rod then rotate the rod and you'll see it pedal go up or down then tighten the locknuts.
Keny73tj
Post by Keny73tj »
Sorted cheers bighug
