NC30 Rear Wheel Split Pin
- thunderace
- Bike owned: R6, YZF600R
Re: NC30 Rear Wheel Split Pin
Just a standard Cotter Pin. Length doesn't matter as you can trim them down or wrap them around.Worther wrote:Hi Folks,
I've had a search for this question, bit can't find the answer...how do I get replacement 'Split Pin' for the rear wheel nut? On my bike it had been on for a while and one 'leg' broke off upon re-assembly.
Is this a Honda only item?
I've looked on Rick Oliver's website (haven't phoned though) and couldn't see it.
Any help would be appreciated.
Thanks,
FWIW, I buy assorted packs of 500 S/Steel ones for about £4 which cover pretty much every application where one is required.
Ill measure it for you if you like, I got it from a bike shop and it said for VFR/RVF on the packet.Marcos wrote:I take it the R clip has to be 2.5mm, how long?
You can see it here.
- thunderace
You missed a bit Neo
- bikemonkey
Neosophist wrote:Ill measure it for you if you like, I got it from a bike shop and it said for VFR/RVF on the packet.Marcos wrote:I take it the R clip has to be 2.5mm, how long?
Did you ever get the measurement for this Neo?
I'd like to get one as I'm always taking my back wheel off for cleaning.
- iDemonix
- Bike owned: '92 NC30
It's just a split pin, get them from anywhere!
Halfords do a multi-pack of them if you're in a rush with about 10 different sizes.
- bikemonkey
I was on about the fancy stainless R-clip
Morespeedvicar
the r-pin on mine is 52mm long over all, i'm liking the idea of a stainless one tho.....
http://www.amazon.co.jp/gp/product/B001 ... 9AHQBEKRBD
This is the one I have, its made my aftermarket maker called POSH.
I will measure it when I get chance
