Changing HT leads on NC29
cbr400rrn
- Bike owned: NC29 CBR600F
IF anyone fancies upgrading their old HT leads its pretty easy as the coil end of the lead is a compression type of fitting as below
and the plug end is a screw in fitting, you can just see the screw in the bottom of the plug cap in the picture below (5 complete 360 degree turns and they are ready for use)
The hardest part is getting the plug leads off the bike
Hope this helps someone.
Karl.
Karl.
- Davez29
- Bike owned: NC29 forever
Re: Changing HT leads on NC29
And guess what I was thinking about looking to upgrade, just last night.. Spot on thanks. As its not something I have done in years and more than likely bodged being a youth, what and where do you get your ht leads from?
cbr400rrn
I got the HT lead from Graeme, its a bit of a struggle but that's probably only because i didn't move the radiator to give me a little bit more room but it can be done with it in situ
400RRJ
- Bike owned: CBR 400 RRJ NC23
Does any one know if the above is the same for the NC23??
- leopard_pagan
- Bike owned: used to have a NC29
PEOPLE> STOP!
you do not need to touch the radiator to do this & become a contortionist.
Tank off
air box off
coil packs accesable & remove them..
lift the rubber skirt & duct tape out the way.
now you can reach the plugs/ht leads piss easy...
TOP TIP: mark the HT leads to coil pack & plugs BEFORE you remove them....
Tank off
air box off
cbr400rrn
Where does it say i moved the radiator?cbr400rrn wrote:its a bit of a struggle but that's probably only because i didn't move the radiator to give me a little bit more room but it can be done with it in situ
- leopard_pagan
Haynes manual tells you to swing Rad forward to access plugs..
far easier to go the other way i mentioned.. yes more to come off but ssoooo much easier & you can see more too
