using carb cleaner
mikey65
Bike owned: 2012 Fireblade HRC NC30 K 1989
Re: using carb cleaner
Post by mikey65 »
Hi just to let you know I put a new battery on she started up full choke and turn over a couple of times then she fired back up. I left her running for a while I used to get problems reving passed 8000 9000 rpm but got her to rev back up to 14000 rpm it sounded as though something clear after that it was fine throttle repsonce is still a bit sticky some times sometimes the refs dont drop down quickly. Still think to giving the carbs a clean will help.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
BB_158 wrote:
CRM wrote:viewtopic.php?f=24&t=14524
just step away from the drill bit in the slides.
Paul,
Curious to know your reasons for your view on this - is it that not possible to go back to std setup?
Cheers BB
Hi, only because the two times / bikes i have done it on it made the bike feel slightly worse each time.
I do believe Honda had a pretty good idea what they were doing, yet for a light pipe change and small mods jetting should be enough to make enough of a difference.
If it works for some - great, but it would be a last resort for me again.
And yes - once drilled you can't go back.
mikey65
Post by mikey65 »
Hi got the carbs off this afternoon cleaning them up on the outside first but tried to get the plates of to see how the jets are and the screws are very very tight tried wd40 left them still no joy. Any ideas dont wont to damage the screw heads.what about a bit of heat from a blow torch??
CRM
Admin NWAA
Admin NWAA
Post by CRM »
blow torch near a carb - have a word mate
if the screws are that seized use small mole grips to start them. then replace all the screws. rick oliver does some nice kits.
mikey65
Post by mikey65 »
cheers
mikey65 wrote:Hi just to let you know I put a new battery on she started up full choke and turn over a couple of times then she fired back up. I left her running for a while I used to get problems reving passed 8000 9000 rpm but got her to rev back up to 14000 rpm it sounded as though something clear after that it was fine throttle repsonce is still a bit sticky some times sometimes the refs dont drop down quickly. Still think to giving the carbs a clean will help.
Not in neutral i hope :spank:
I also agree that the slides dont need drilling but if you do ever need to go back just fill the hole with resin and drill to stock size.
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Post by krisztian_andre »
You can get a gasket set for 20 GBP.
mikey65
Post by mikey65 »
just got one of the covers off the back carb looks in good condition jets all look clear and clean put noticed the main jet is 120 not 110 as standard my bike has a standard exhaust will this make any difference?? also the main jet was not screwd all the way in on the thread any ideas. I will check the others to see how they are looking.
mikey65
Post by mikey65 »
just checked the back 2 and they are 122 jets thats the same as a uk spec bike as to cammo's description so should i put in 110's all round as my bike is standard also the treads dont go all the way in on the back to either.pilot jets look ok as well.
mikey65
Post by mikey65 »
Got the carbs back on not easy but started her up and what a difference. Thanks guys for the support.
