GK76 rear shock fitments?
topfridgeman
Bike owned: 1 or 2
Post by topfridgeman »
Hello,
Does anyone know which other rear shocks with fit or very nearly fit the gk76 model gsxr?
Thanks, Col.
DirtMcGirt
Bike owned: GK73A
Re: GK76 rear shock fitments?
Post by DirtMcGirt »
dsr91
Bike owned: gk76a , 92
Post by dsr91 »
i fitted a k7 rear shock to mine with 20mm jack up link arms from projections , you dont need the jack up kits to fit them tho , but if you do buy a k7 shock try to find one that has the gas adjustment thing at 90 degree angle sat on top the shock , it makes it much easier to fit and no need to modify battery tray or airbox but you willl need to modify bottom linkage a little bit only takes 30seconds to modify ,also k7 shock is same hieght as standard one .
gsxrkev
Post by gsxrkev »
gsxr k7 600 shock?
dsr91
Post by dsr91 »
gsxrkev wrote:gsxr k7 600 shock?
I believe 600 fits the same but I brought a k7 ,750 shock from 2009 bike
