Nc30 engine spacer size ?
Dynamohum
Starting a build but have mislaid the bottom right spacer that goes between engine and frame on the long adjuster bolt 26 on the parts fiche which shows as 12mm which I take as m12 bolt size? I have one on other bikes but it's not practical to borrow remove , tried David silvers and lings but part nla
can anyone give me the dimensions of this part?
- VFRkieran
Re: Nc30 engine spacer size ?
Bugger if you had posted this just the other day id have measured it up for you, ive put the bloody engine back in the frame now
Dynamohum
Hunted high n low in garage must have rolled of when I stripped bike 5 months ago serves me right for being slow in rebuilding... Thanks anyway kieran .
Dynamohum
arsey30
- Bike owned: ftr223 650 bros
Why not measure the width of the engine and the space between the frame and calculate the difference?
Dynamohum
Looks like that's what I'm gonna have to do then I take it a m12 washer of the correct thickness is all that's required
