Nc30 fork rebuild , internals query
Gennery_13
Looking at replacing the seals bushes and oil on my nc30 forks , forks are apart of a custom build so not sure what year they are from, forks details -
Showa MR8-781
Fork diameter 41mm
Some Japanese writing with the number 10
Would be very greatful if some one could shed some light on what year or what bushes seals and w oil I would need.
Karl
Showa MR8-781
Fork diameter 41mm
Karl
scotjell
- Bike owned: VFR400 NC30x2
Re: Nc30 fork rebuild , internals query
Pics help and if you look at a thread about fork tubes some have 4 holes near the bottom and some have two this will give us an idea. The legs are the same on both early and later types.
Gennery_13
Not sure which holes your on about is it the holes indicated with the green arrow ? Bushes I'm after are below the red arrow
The NC30 has two types of forks.. early and later type.
The slider and guide bushes are the same between forks but other parts may vary.
Later type forks fiche is here.
http://www.akhara.com/nc30/nc30parts/files/27.htm
Early type forks are here.
http://www.akhara.com/nc30/nc30parts/files/26.htm
If you copy and paste the part numbers into the search for parts box on www.davidsilverspares.co.uk you can order from them.
scotjell
