NC30 clock change and no start.
Re: NC30 clock change and no start.
Varta, yuasa,
- vfrman
- Bike owned: NC30, 1098s
- thunderace
- Bike owned: R6, YZF600R
Ersan, were you not advised to buy a new battery several months ago?
- xivlia
- Bike owned: Ducati 749 D
this is my second battery. but its fucked also by the looks of it.
- NGneer
Drunkn Munky wrote:If i was a betting man id put money on it starting straight away with new plugs and battery.
Once or twice to check it works is fine but after that you need to take it for a good run or you will just start killing more plugs / battery as they need to run for enough time to get up to full operting heat (effectivley what you keep doing with the gas cooker or blow torch).
- xivlia
well. if there is spark on plugs, does that mean they should operate correctly but are not because of battery or.... can plugs be dead even if the all spark? cause i will buy a new battery, but i dont want to spend 40 quid more on plugs if they are not dead..
- thunderace
The spark should be a nice rich blue colour. Just because a spark looks OK though, doesn't mean the plug will work under load.
- xivlia
hmm okay, well it is nice a blue and it sparks for a great distance when moved away, but then it sparkes me
- thunderace
xivlia wrote:but then it sparkes me
I don't think anyone would call you a bright spark
- Bike owned: VFR400
Before you spent more money on another battery, why not do as other have suggested and put the current battery on your charger at least overnight.
