the bike doesn't start when it's hot !! Help !!
bido600
hey guys
i got nc23
start very well when its cold
when it gets hot or warm no way i can start it
so i have to jump start it
this problem just came today
i have new reg/rec
new battery
just got them 2day
when it cold it start very well but when it gets warm the battery act like it's dead so i leave it for 10 min and it start
any ideas
so is it electrical prob or something else ?
i got nc23
i have new reg/rec
new battery
just got them 2day
any ideas
gullarm
Re: the bike doesn't start when it's hot !! Help !!
Did this problem only occur when you put on the new batt and reg/rec????????
Because if it did you have done something wrong when installing.
I would try the starter relay 1st, bypass it and see if it goes. Mainly because its easy to get to. Check all the cables are secure.
Then check the bushes on on the starter motor! It may go wrong when it gets hot from the engine running!
It could also be the starter button, or the kill switch this happened on mine. Press the button and nothing happens, cos it aint working. You can bypass both from the connector block
If you can push start it down the road when its warm its more than likely to be the relay and/or starter.
bido600
yes sir this prob occured when i got the new reg/rec and batterygullarm wrote:Did this problem only occur when you put on the new batt and reg/rec????????
my old rec/reg was giving lots of votls which made my battery boil and drop acid all overthe place and wires then i got the new reg/rec and install old batter i have its not givin power so i got the new batt
dono if the old reg/rec blow anything else
- petrolhead19
I had the same problem with mine, new battery and reg/rec fitted but wouldn't start when it was warm.
I needed a new starter solenoid anyway so got one and its not done it since.
Also over charging of the battery for long periods of time can fry the cdi
bido600
well sorry for asking cause am confusedpetrolhead19 wrote:I had the same problem with mine, new battery and reg/rec fitted but wouldn't start when it was warm.
after u got new starter the problem solved ??
or still ?
Hutch58
- Bike owned: NC23, RGV250, NC30, YB100
If your battery was boiled by the reg?rec then you will need to replace it. It would have been severely damaged.
- petrolhead19
It solved the problem when fitting the new starter solenoidbido600 wrote:well sorry for asking cause am confusedpetrolhead19 wrote:I had the same problem with mine, new battery and reg/rec fitted but wouldn't start when it was warm.
or still ?
willpisme
- Bike owned: NC30, R1, CB250RS, FZR400
i had the same with a new reg/rec + batt. turned out the be the CDI at fault in my case
