problem
xivlia
Bike owned: Ducati 749 D
Re: problem
Post by xivlia »
ive not connected the new clocks yet, i mean the original clocks. the r/h switchgear is connected otherwise how can i press the ignition button? i removed the battery leads, not touched the reg/rec other than remove the connector block. Speedy, the CDI was disconnected, but everything is all connected back to its original place, why would i try to start the bike without a CDI or reg/rec etc, everything is all connected. :P
speedy231278
Re: problem
Post by speedy231278 »
Just thought. Didn't this happen the last time you ripped the subframe off? Then after swapping CDIs back and forth, and poking other circuits, everything cam back to life? Methinks your loom has got a dodgy connection or two that you keep upsetting. Like my bloody reg/rec... :s
speedy231278
Re: problem
xivlia wrote:why would i try to start the bike without a CDI or reg/rec etc, everything is all connected. :P
What I meant was that you've unplugged it, and then plugged it back in. You might have disturbed a dodgy connection in one of the plugs, or have a wire that's broken inside the insulation that keeps losing contact.
xivlia
Re: problem
Post by xivlia »
hmm yeah this happend last time too. but last time was actually the CDI fault. it was a faulty CDI, when i got a new CDI it worked straight away, but yes i am also thinking it could be a dodgy connection somewhere... i just need to trace it back, but i will not do that tonight because its going to get me even more frustrated if i do.
ibby4585
Bike owned: SP's
Re: problem
Post by ibby4585 »
I think it's going to be one of those things where you have to retrace what you have touched and check everything.
Charge the battery first though and clean the plugs.
porndoguk
Re: problem
Post by porndoguk »
98 pages to go....
i blaim fox piss or maybe a dodgy trigger wire from cdi to coil packs.
its cranking so safety circuit is closed, so no spark would be kill switch, dodgy coils or supply to the coils.
ibby4585
Bike owned: SP's
Re: problem
Post by ibby4585 »
A knackered battery gives a shite/no spark doesn't it Rick.
porndoguk
Re: problem
Post by porndoguk »
ibby4585 wrote:A knackered battery gives a shite/no spark doesn't it Rick.
yes but if its cranking then there should be enough power to fire a spark
xivlia
Re: problem
Post by xivlia »
wait, does trying to crank with low batt kills the plugs?? i didnt know that...
Re: problem
it kills them as they get flooded....
