Carb compatibility
fasttom
- Bike owned: VFR 400 NC24, Kawasaki Z750
Carb compatibility
Hi all,
Will NC21 carbs work on an NC24? I believe they have the same diameter inlet (32 mm) but potentially different jets. If I were to swap jets from NC24 carbs to NC21 would they work?
Thanks in advance.
Tom
Thanks in advance.
Tom
Re: Carb compatibility
Yes but dont do it.fasttom wrote:Hi all,
Will NC21 carbs work on an NC24? I believe they have the same diameter inlet (32 mm) but potentially different jets. If I were to swap jets from NC24 carbs to NC21 would they work?![]()
Thanks in advance.
Tom
NC21 carbs are 30mm inner diameter and have 110/112 jets.
It will work but the NC24 carbs are better and run better with the bike
