Headstock tighten
Mole
Headstock tighten
Hey guys, is it easy to tighten the headstock?, i got a caution on my M.O.T, and now it's a few months after i can hear a tiny knock when i go over bumps.
NC30V
- Bike owned: NITROUS NC30
Re: Headstock tighten
easy enough, remove top yoke there are two locking nuts tighten the bottom one then the top.. using a c spaner, be carful not to go too tight as steering will be stiff!! then re fit top yoke job done!!!
good look
kev
good look
kev
- Sligeach
as long as you can get the front of the bike off the ground, its easy.
you need the front off the ground so you can see that the bars can move free enough.
you need a 41 socket, i think
- mattUKNC
Mole
Cheers guys, do you know where i can get some new locking washers, one of mine the tab has cracked, and know what size i'd need?
- Sligeach
http://www.davidsilvers.co.uk" onclick="window.open(this.href);return false;
