Ebay, won rear disc,
- xivlia
- Bike owned: Ducati 749 D
Okay so i just managed to snipe this item in the last second with my android app
and was wondering what make this is? i havent seen this before, and it doesnt look like the cheap Chinese ones. Any ideas?
http://www.ebay.co.uk/itm/181033755722? ... 1423.l2649
cheers.
cheers.
- speedy231278
Re: Ebay, won rear disc,
Gawd knows, but it looks pretty marked up on what little friction surface the thing has! I hope it works better than it looks.....
- alexwitham
Looks like a well used disc that was blatantly designed with weight saving in mind, not stopping power.
No idea who the manufacturer is
- thunderace
- Bike owned: R6, YZF600R
That looks pretty fcuked to me. It also looks as though it's got quite warm at some point, you may want to check it's straight before you fit it.
- xivlia
yeah il get a closer look at it when it arrives, i just didnt want to spend 30 on chinese stuff and i wanted a wavy disc purely on its looks. 17 isnt too much anyway, if its crap. then i will need to buy some other one. il check its thickness etc. it says its got plenty meat left... im guessing atleast 6+mm and il check if its straight.
Tap it with something metal whilst you suspend it with string, it should have a nice ring, if not it could be cracked etc
- alexwitham
And to check if it's straight, go outside and throw the disc along the floor, so it spins on its side, then lay down in a half suspended press up position directly behind the disc and see if it's wobbling from side to side at all. Acceptable tolerances is circa 2feet.
- xivlia
- NGneer
alexwitham wrote:And to check if it's straight, go outside and throw the disc along the floor, so it spins on its side, then lay down in a half suspended press up position directly behind the disc and see if it's wobbling from side to side at all. Acceptable tolerances is circa 2feet.
Ersan, I would be very wary about buying second hand brake discs at all and certainly of E-bay where someone will always quote "plenty of meat left" but never actually quotes the thinkness of the discs (or even probobly knows the limts of wear).
Hand on heart I hope you have picked up a bargin and it turns out to just need a clean up and still has, as they say, "plenty of meat on it". But I susspect you will be disapointed and in that case fitting it will be pointless as, if it looks a s bad in real life as it does in the pics, it would get picked up as a 'Fail' at any re-run at the MOT.
I know it it a bit late now as you have already bought it, but rather than taking a chance for just over 20 quid, and a good chance you will have to bin it anyway and start again.....why not just buy a 'New' rear disc from a highly reliable source for just a little more and know 100% that it is good, staright and quality?
[Exctract from Rick Olivers price list]
Brake Discs -
Rear - Pattern round stock replica £36
Arashi wavy £39
Looks scored to buggery.
For someone who can barely afford to keep their bike running, a fcuked used disc hardly makes for a wise investment!
