'91 nc30 no pickup after change new cdi
dinv4
Need help .....
My nc30 change 2nd hand cdi ( bought from ebay-seller said can be used for all years nc30 ).After install,my nc no pick up during rev.
My mechanic said,the new cdi have extra 1 wire.but I not yet see the cdi due to at workshop.
If have opinion,pls advice.thanx a lot.
viper_biker
Re: '91 nc30 no pickup after change new cdi
Do you still have the old CDI? If so, try it and see if that sorts it. If it does then it's a faulty CDI.
- superlite
- Bike owned: TLS, LB80 x 2
What were the symptoms with the old CDI?
'Take it to the Back'
dinv4
old cdi burn .....
the extra wire is blue/yellow color ..... maybe the wire is used for cut-off??
Do you mean that it revs but not well?dinv4 wrote:Need help .....
My nc30 change 2nd hand cdi ... After install,my nc no pick up during rev.
The blue/yellow wire will cut spark to 2 cylinders over 5000 rpm if fiddled with and is also associated with the speed limiter/dash.
You problem lies in this wiring. I would take the bike to someone that knows Nc30's inside out, it will cost you less in the long run.
dinv4
sorry ... the extra wire is orange/blue ..... my previous cdi don't have that wire ( even from main connector also don't have,only using 5 wire).
After change new cdi,have extra wire orange/blue.
Who can explain to me,function/connection of that wire,becoz my previous bike not using it.Maybe after know the connection for orange/blue wire,I can manually connect the wire to correct position.
NC35!
Hi
There is no orange/blue on the wiring diagram, at least not coming from the CDI. There is a blue/yellow and yellow/blue, both for the coils, and there is a blue/orange for the oil pressure lamp, but no orange/blue.
Are you sure your new CDI is actually an NC30 device?
Thanks.
The wiring diagram for the NC30 is here:
http://www.green-flight.co.uk/images/NC30wiring.jpg
Thanks.
- Gavin jap4
WHATS THE CODE ON THE CDI
GF Racing
Sounds like a UK versus import CDI to me ...
Give me a call sometime - will try and expalin all.
Graeme
Tel 07778 628448
Graeme
Tel 07778 628448
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
The haynes is wrong. The orange/blue from the cdi is the speed limiter wire.NC35! wrote: There is no orange/blue on the wiring diagram, at least not coming from the CDI. There is a blue/yellow and yellow/blue, both for the coils, and there is a blue/orange for the oil pressure lamp, but no orange/blue.
