what brakes fit nc35?
- speedy231278
- thunderace
- Bike owned: R6, YZF600R
Re: what brakes fit nc35?
I'm pretty sure the original 'Blade had the same M/C as the NC35.
yeah, VFRman steve sorted me out the top man that he isNeosophist wrote:Ah that will be the 92 blade then, did you get your MC sorted because I think I have a 92 blade MC knocking around..
NC35 was a 14mmCMSMJ1 wrote:What size is the RVF? 14mm? or 5/8?
they started fitting 14mm M/C after the initial run of 1992 modelsspeedy231278 wrote:Would be interesting to know what size it is, everything I've found so far for the Blade says 14mm (9/16) for 1992-1997. Wouldn't be the first time the aftermarket people got something wrong.....
again Rick Oliver said "What you need is not hard to find - it`s the master cylinder which was
used on the RC30 and early model Fireblades."
I have a 5/8ths blade m/c on my bike and it looks identical to the original 14mm that was there. My brakes are bob on.
Saying that, I have not ridden the old beast for some time and need to get out this weekend for a razz if I can
Later ones deffo had 14mm.porndoguk wrote:yeah, VFRman steve sorted me out the top man that he isNeosophist wrote:Ah that will be the 92 blade then, did you get your MC sorted because I think I have a 92 blade MC knocking around..
These Nissin kits are nice, 3/4 size 80 quid.
Was looking at an NR750 MC for my bike.. they are 14mm so match stock 30 :)
nr750
so they share the same part number then?
- speedy231278
Ah, so it's like the very early NC30s where according to Mike Lohmeyer's page, the first particular number off the line had slightly different clutch plates to the rest of the same year? No wonder people get confused!porndoguk wrote: they started fitting 14mm M/C after the initial run of 1992 models
are these the ones your trying to flog for £90-100 in the for sale section?juggernaut wrote:What is the ratio of the front master cylinder?
I've just got some good condition sp1 calipers for £38!!!! and wanted to know the ratio as I may look at a fancy master cylinder.
Luke
- thunderace
porndoguk wrote:are these the ones your trying to flog for £90-100 in the for sale section?juggernaut wrote:What is the ratio of the front master cylinder?
Luke
Ownd!
- speedy231278
Think I paid £74 for mine, but they came with Goodridge hoses and a MC (albeit stock NC35 one). I've seen them fetch over a ton a pair, and go for a tenner each individually. Supply and demand.... Currently, the cheapest on eBay is £50 a side. Cheap stuff comes to those who wait...
