Effect of discs past minimum thickness?
- speedy231278
Re: Effect of discs past minimum thickness?
Assuming they even bother to measure them.....!Morespeedvicar wrote:And it wont pass its next mot..............
I don't think so.jetblack wrote:oh god, i'm not suggesting using them past min thickness, they're a little way off that yet.
I just want to know if the braking effect is reduced the thinner/closer to min thickness that they get or does the braking efficiency not directly correlate to the efficiency?
Honda / whoever do extensive testing to find the limit point of the brake disc, they then set the minimum thickness ABOVE this level to ensure that the discs should always be replaced when they are in safety zone.
You shouldnt have any issues running them upto the minium thickness zone, providing there not damaged.
pip
Re: Re: Effect of discs past minimum thickness?
Agree'd. I'm not saying it's wise to run below min thickness but there will be a decent safety margin built in.Neosophist wrote:I don't think so.jetblack wrote:oh god, i'm not suggesting using them past min thickness, they're a little way off that yet.
I can't see them having reduced stopping power. Might even have more due to the larger area because of the wear lip lol
Pip
andy1472
- Bike owned: VFR NC21
They don't ever bother measuring disks at all the garages I've had bikes tested at. They prob can't even spell micrometer, let alone use one.
Just change them mate or walk!
Jashdown
Better handling, less unsprung weight. Lawl.
Morespeedvicar
Alot of mechanics can spot nakered discs a mile away, and usually only dig out the mircometer if something looks nakered! Well all the ones i know do anyway...
But yeah lessweight go faster, or just make the holes in them bigger aswell..............
