NC29 BHP
Re: NC29 BHP
reason i listed that lot was *IF* your a BHP junkie, that 1/2 BHP all adds up!
personally my chain is lubed when it rattles, my throttle has a wee bit of lag* and i cleaned my filter last summer!
*lag is when you open the throttle........ then the bike reacts. a well set up bike will be instant.
rear wheel alignment is important, if the chain isnt running true, it will create friction as it comes off/in the sprockets and loose you that all important .3 of a bhp!
oh.. BTW did you know you gain 2BHP per HRC sticker you put on your bike?
- superlite
- Bike owned: TLS, LB80 x 2
Re: NC29 BHP
That doesn't lower your power output though, and won't show up on a dyno. Just as a quick turn throttle doesn't give you more horsepower, it just allows you to access it more quickly.leopard_pagan wrote:*lag is when you open the throttle........ then the bike reacts. a well set up bike will be instant.
The best performance gain you can get is cutting back on the pies IMO - actually saves you money
'Take it to the Back'
- Thieving Pikey Twat
Re: NC29 BHP
alexibrow wrote:Cheapest way to hit redline in 6th? Change the sprocket ratio!wont pull to redline in 6th gets to 12.5-13K and stops which is 125-130ish but would like to see if I can get it to pull to redline in 6th
Or go and play in Germany
Re: NC29 BHP
oh.. Altitude also has an affect on BHP.... true readings from sea level . cant remember if they go up or down if your higher/lower on where its dynoed.
Re: NC29 BHP
There's less oxygen the higher up you are, so your mixture goes rich.Altitude also has an affect on BHP
Re: NC29 BHP
Can now hit redline in 6th with 14t front sprocket
as found out it was restricted to 180kph so fitted de-restricter easy
Re: NC29 BHP
If you want to 140mph, your gonna need to have about 70bhp, a 37 rear sprocket.. and a long straight.. :) Col
- Bike owned: some ZXR400's, ty175, mz ts125
Re: NC29 BHP
or a zxryeurman wrote:If you want to 140mph, your gonna need to have about 70bhp, a 37 rear sprocket.. and a long straight.. :) Col
Re: NC29 BHP
ha ha... I dont think so.... at the Manx this year all the top speeds down the Sulby Straight were set by Hondas, RVFs, then CBRs. My NC29 clocked 135.8mph and the fastest RVF I think was 138ish mph. The ZXRs might be the best on closed circuit racing but Honda rules the roads...
Re: NC29 BHP
interesting.. zxr's are quicker stock, and make more power tuned .. maybe its a "peakiness" thing means the honda's can pull higher gearing
got a link to the top speeds/laptimes ?
