Carb Slide Lift
- abrmoto
Carb Slide Lift
I have fitted a new set of carbs to my race bike, new ram air from RLR but one of the slides refuses to litf, hence running like a bag o shite.
Slide lifts and falls at same rate and ease with a finger as other, so think a air way must be blocked, any ideas where to look first??
Would ask Rick at RLR but he is at the NW200 so dont want to bother him.
Aly
mail@abrmotorsport.co.uk
Aly
tarmac
Re: Carb Slide Lift
the bigger tube vents feed the top of the slide try blowing some air from the compressor through that. The slides should lift.
The comp should be set to a low pressure. 30psi should do. lightly press the trigger on the blow gun.
- monkeywithaplan
- Bike owned: NC35 and NC30
Re: Carb Slide Lift
as tarmac said.tarmac wrote:the bigger tube vents feed the top of the slide try blowing some air from the compressor through that. The slides should lift.
would also check carb to engine rubber for seating and any cracks or splits.
- abrmoto
Re: Carb Slide Lift
Sorted,
Wont go into it, but lets say the inlet was blocked, some peeps never learn
Aly
Aly
thefatman
Re: Carb Slide Lift
Write out 100 times, I will not poke things into my carbs and expect the bike to run properly!
- abrmoto
Re: Carb Slide Lift
Actally just finished my lines, and they read "I must not leave tissue shoved down the inlet port when I have fitted the carbs and expact my bike to run"
Re: Carb Slide Lift
LOL- that is a good one Aly...
- abrmoto
Re: Carb Slide Lift
Would not mind but is the second time I have done it in 3 months!!
viper_biker
Re: Carb Slide Lift
PMSL!!! That's why I now use a towel to cover all 4 inlets.abrmoto wrote:Actally just finished my lines, and they read "I must not leave tissue shoved down the inlet port when I have fitted the carbs and expact my bike to run"![]()
- CRM
Re: Carb Slide Lift
Lol - not again Ali ? i remember oulton park a few weeks back
