looking maps for ignitech vfr400 nc30
karikeo
I'm thinking of buying a cdi ignitech, because there is no longer hrc modules
anyone know where I can get the maps for vfr400 nc30
- petrolhead19
Re: looking maps for ignitech vfr400 nc30
The unit should come with a cd with the software and maps.
I got mine from Graeme france and had a hrc map already loaded on the unit for around £175
I think Rick o does them for the nc30 aswell with map already on for around £135
Yeah rick does them with a CD of all the maps for £135, dont be suckered into buying the ones off ebay for £200, there exactly the same unit.
I woudlnt buy one at all.karikeo wrote:I'm thinking of buying a cdi ignitech, because there is no longer hrc modules
unless youve done some major engine work or been changing cams / pistons etc then I cant really see a use for it.
Rick did some back to back dynoing with a stock unit and there wasnt any improvement if I remember rightly, certainly nothing for spending over 100gbp on.
What are you wanting it for / expect it will do though I guess it the question.
karikeo
that is the cdi hrc ignitech and maps I have not have any improvement in my motorcycle standart
- petrolhead19
I have noticed a difference on the nc23 in performance but i have tuned carbs and everything else done lol
The HRC map is designed to work with the HRC cams / pistons and everything else, without all that it doesnt do anything for the bike.karikeo wrote:that is the cdi hrc ignitech and maps I have not have any improvement in my motorcycle standart
lukemillar
Yep - Neo is right. I have been doing a lot of reading of late on ignition advance and why the ignition needs to be advanced at different loads/rpm and unless you have tuned your engine substantially from stock, there seems to be little gain.
Sometimes I think people incorrectly think of ignition mapping being the same as fuel mapping on FI engines.
