Rear Hugger for my RVF400 Project
Hey Guys
looking at a rear hugger for my RVF400 project and was after you thoughts on what i should be looking at or if you could point me in the direction of a good one that you guys use?
Im restoring a RVF atm and im using a VFR wheel 18 Inch. was looking on ebay and saw this.
http://www.ebay.com.au/itm/380465368355 ... 505wt_1320
Im assuming that would work and fit snug as im trying to fit an 18 Inch wheel. if somone could shout me some advise that would be great
Cheers in advance
Cheers in advance
- speedy231278
Re: Rear Hugger for my RVF400 Project
I guess it would depend on the mounting points, unless you are prepared to modify the thing to fit. You may find that they are rather different. I would have thought that an NC30 hugger would be closer in fit? The part numbers are one digit different, and it is the last digit, which normally means it has been superceded by a compatible part. Having checked with DSS' website, the chainguard for the NC30 40510-MR8-780 is listed as being superceded by 40510-MR8-781 (NC35), so the mounting points must be the same spacing or the part for the NC35 wouldn't fit, and would have a substantially different end number. If it was modified to suit the 35, the logical part number would be 40510-MR8-900.
However, I guess the VFR750 has a wider rear wheel, which could cause clearance issues, of course. I guess that's why you're looking at the above rather than one for an NC. Best bet would be to find someone who owns the 750 model your rear came from and ask if they'd measure up the mounting hole spacings.....
Yeah ok so anyone got a VFR with a 18inch rear with a hugger out there haha.
Im using an old VFR rear wheel not one off the 750 i dont really know where this one has come from i bought a whole lots of bits with this project and the guy i bought it off had this 18inch rear.
Ill do a bit more reading but anyone out there have a hugger on there RVF that fits snug?
- speedy231278
Sorry, not quite sure where I got the idea you were using the 750 wheel from! Out of curiosity, why fit one to a 35 when supposedly the tyres are hard to come by with much in the way of choice and it'll alter the geometry, never mind play havoc with the speedo?
Just get an NC30 hugger. sorted...
You won't havea 750 18 inch rim on there....if you do, you're the first I have heard of.
