New regulator?
marti
New regulator?
Ive just bought my mates nc, its stood for a while so new battery and fuel and were running.
I measured the battery voltage when running and it was 17v!
I checked the regulator connections etc and its all good.
Is it time for a new regulator?
scotjell
- Bike owned: VFR400 NC30x2
Re: New regulator?
what was the revs at when giving 17v? Usually run it up to 5k and see what you get.
- petrolhead19
Re: New regulator?
Dont run your bike again until you get a new reg/rec or you will fry your nice new battery and could damage the cdi.
at 5k it should show between 13-14v, if its showing 17v on idle then it will more than likely be around the 20v mark at 5k so will defo fry everything, trust me i did the same and it fried my new battery and my cdi
amorti
- Bike owned: CB-1, MSX125
Re: New regulator?
petrolhead19 wrote:Dont run your bike again until you get a new reg/rec or you will fry your nice new battery and could damage the cdi.
Running a charged battery or a bike at all for even a relatively short time at 17+ volts will cause you issues and boil your battery. Get a new regulator on there.
marti
Re: New regulator?
Thanks for the correct diagnosis ,tried a mates regulator and it sends 14.5 volts to battery!
I think im gona get a reg off a r1/r6.
Anyone got one?
Anyone got one?
Re: New regulator?
Forsale or using?marti wrote:Thanks for the correct diagnosis ,tried a mates regulator and it sends 14.5 volts to battery!
Anyone got one?
I use one there great. Plenty of info on how to fit one and its dead easy to do.
The Novice
Re: New regulator?
Which year r6/r1 reg/recs fit?
- petrolhead19
Re: New regulator?
correct me if im wrong but i think the r6 5sl model one fits.
marti
Re: New regulator?
Found a cb500 rectifier at a local breaker for a tenner!
Sorted
Sorted
