Connector block for Reg/Rec
Hi,
Does anyone know if its possible to buy the 6-way connector block which plugs into the regulator/rectifier please?
Thanks!
Thanks!
Re: Connector block for Reg/Rec
The only thing I can think of is that http://www.electrexworld.co.uk/" onclick="window.open(this.href);return false; do the Reg / Rec with connectorblock, if you email them they might sell you one on its own as they are a nice company.
Rick Oliver may have them also
You can buy the 2 sizes of spade connectors at most good electrical shops, just make sure to solder them into the loom.
Hi,
Thanks for the link above, I think I may replace the reg/rec while I'm at it - as best as I can determine the original is an OE unit, so better safe than sorry I guess!
I've had reg rec's and generators for a 24 and a 35 off them and their service has been great. Check wemoto as they often do the same reg/rec's cheaper than electrexworld... :)
- Bike owned: zx9r c1
vehicle wiring products have a good selection of goodies,also try http://www.autoelectricsupplies.co.uk/...." onclick="window.open(this.href);return false;.
