NC35 - AFAM Sprocket Question
- Bike owned: NC35, Monster S4R, MG 850T
Hey Guys,
I'm installing a 15 tooth AFAM front sprocket on my RVF.
However it looks like one side towards the center is wider than the other.
Does the wider side face out or the shorter one?
Thanks for your help!
- ibby4585
- Bike owned: SP's
Re: NC35 - AFAM Sprocket Question
I'm pretty sure the 35 is the same as the 30 and the larger shoulder and writing sits on the outside.
Kris
Kris
- Bike owned: ktm200exc gsxr400gk71b sv650
Normaly if it is stamped with numbers they face outwards.
- Speedy
- Bike owned: RVF400RR, ER6n
Don't wish to confuse things, but the O.E. sprockets come with equally sized shoulders, in which case the Afam wider shoulder should face in, so as to offset it as per standard?
Here's a pic off David Silver that may help decide:
If its a 520 conversion front sprocket the wider sholder will face outwards 525 pitch looks even.
Awesome...thanks for the help!
- Speedy
Ah yes, it does make sense if the pitchs are different!kevprojex wrote:If its a 520 conversion front sprocket the wider sholder will face outwards 525 pitch looks even.
Cheers.
- Lane
- Bike owned: MC21,MC22,NC35's,VJ22
If in doubt, sit it on the spline in both directions and peer down the line from the rear sprocket, you will be able to tell the correct orientation from this perspective.
