NC30/35 Power Loss with Ignitech Ignition - The Solution
hunter
Re: NC30/35 Power Loss with Ignitech Ignition - The Solution
Post by hunter »
what's the red boxop right of the pic,NO CONNECTION WITH PC.
Mine is showing this,is it normal.
RickOliver
Post by RickOliver »
Assuming that the unit is actually connected to your PC then that `No Connection` flag means that the box is not powered up - it needs to be on the bike with the ignition turned on in order to accept programming...
Rick
hunter
Post by hunter »
Thanks for the reply rick.
Lane
Bike owned: MC21,MC22,NC35's,VJ22
Post by Lane »
So am i right in assuming that these will now give a better power figure on a modified engine than the old version which seemed to do very little?
Lane wrote:So am i right in assuming that these will now give a better power figure on a modified engine than the old version which seemed to do very little?
No it means the unit wont be down on power compared to a standard or HRC unit when its loaded with the relavent map, how you adjust the unit to suit a modified motor is down to you or the tuner.
Lane
Post by Lane »
Yeah what i meant was a reputable tuner of the vfr/rvf's here has spent hours and hours of dyno time and couldn't really find much, if any extra power, despite the state of tune, thus he advises most people to stick with the stocker.
pauliealdridge69
Bike owned: Nc30,35,998s
Post by pauliealdridge69 »
I get a better mid range and feel using the ignitech over the standard ecu on my setting...everything is more crisp etc. and you can go to higher revs but top end was down on standard...now you can set the unit up for better results at lower revs and not loose anything up top either! Makes it worth while.....before there was no point getting one really as any thing you gained was lost up top....
hannakournikova
Bike owned: NC30, NC35 & SP2
Post by hannakournikova »
From just reading this just shows how much of a top fella RO is and how he re-invests into the scene.
Last edited by hannakournikova on Fri Jul 13, 2012 4:12 pm, edited 1 time in total.
Lane wrote:Yeah what i meant was a reputable tuner of the vfr/rvf's here has spent hours and hours of dyno time and couldn't really find much, if any extra power, despite the state of tune, thus he advises most people to stick with the stocker.
But that was before the fix, id put money on it now that a good tuner could make more power up top on a modified motor now the issue has been addressed.
dx400r
Post by dx400r »
thanks for the tip off Rick. Will get and change this on our F400 machine asap.
