carbs
carbs
hi
i have just cleaned my carbs and bike running fime, the only thing is that when i pull the choke lever its ok but when pushing it back the cable seems to go loose, i must be doing something wrong,
can anyone help ?
also i think i may need to have the bike tuned slighly as when ticking over the engine note changes very slightly, is this normal ?
can anyone help ?
- Bike owned: RVF400
Re: carbs
Bro just take the tank off and have another look, you may need some grease on the choke slides on the carb body (they slide left n right) or maybe just an oiled cable. Make sure the screw clip that holds the cable is on the metal tip of the cable not on the rubber lining.
