adjusting chain slack
- Bike owned: vfr400 nc21
hi is it ok to adjust chain slack with bike on side stand
or raise rear wheel of ground using my abba stand
cheers
cheers
- Deviant400
Re: adjusting chain slack
you should adjust chain on with the bike on its side stand
viewtopic.php?f=62&t=27307
ok cheers
- Bike owned: 1990 NC30
I found it easier to adjust on the abba stand, then drop it onto the side stand to do the final measurement/check.
Mind you I was having a thick git moment with the bearing holder etc, etc
Anyhow for what its worth, I found I could measure the slack in various places with the bike on the abba stand, get it within tolerance at the tightest point and then drop it onto the side stand to check it again, there was pretty much sod all difference between the two measuremenst tbh and then as a further check I removed the abba stand and checked it yet again............. I'm clearly a belt and braces sort of person
- Bike owned: 97 NC35
Just did my rvf chain tension with my dad and its very fine on the adjustment-only needs the slightest of movement for a big change. Is this normal? the gauge decal shows it right on the edge of the red/green with a recent chain and sprocket before i bought it. Should i suspect the sprocket ratio is not O.E. i.e. lower-it does go rather well on acceleration! 60 mph shows just under 6k in top?
