left hand switch controls
scottser32
Post by scottser32 »
well i had trouble with the push button beam switch on my nc29 1994 model cbr but that got fixed but the low beams still aint working i bought a 90-93 switch controls but the mechanic said it wouldn fit so is there any fix for the low beams or does anyone have a working one from a 94 model thanks
Davez29
Bike owned: NC29 forever
Re: left hand switch controls
Post by Davez29 »
You might find an nc35 switch will fit, not sure if its the same connections but it is the same switch arrangement, maybe even some other vfr/cbr from 94/95 will be the same . If low is not working maybe you got the contacts wrong on fitting?
scottser32
no it wasn working at all and the main thing is the connections i just need a straight swap i dont want to start fiddling with loadsa wires that i dont have a clue about
Davez29
Post by Davez29 »
I have a RVF400 switch (not for sale) but never checked if the plugs are the same. here is a picture of the main plugs, maybe you can check. It would give you more options on ebay if it is the same.
scottser32
its alright lads i got one of graeme thanks anyways
blackduck
Bike owned: cbr400rrj
Post by blackduck »
scottser32 wrote:well i had trouble with the push button beam switch on my nc29 1994 model cbr but that got fixed but the low beams still aint working i bought a 90-93 switch controls but the mechanic said it wouldn fit so is there any fix for the low beams or does anyone have a working one from a 94 model thanks
i had same issue with my low beams... opened switch to find contacts not touch due to wear and age. inserted peice of plastic about 3 mm thick between switch and side and away worked my lights!!!! 5 mins max :grin:
