NC30 missfiring as it warms up - mega frustrating
Darley26
Re: NC30 missfiring as it warms up - mega frustrating
The symptoms of limited mode do sound very simialr to what i have but then so do the plugs, so i will try plugs as the first port of call, as you said, try the easiest one first.
If this doesnt solve the issue, what are possible causes for the bike to enter limited mode/ things i should look at, as i am gonna have a good session on it at the weekend and try and get it resolved
In my experience the bike will still run smoothly when in limited mode, albeit with less power. It doesn't sound like yours is limited.Darley26 wrote:The symptoms of limited mode do sound very simialr to what i have
Another here for plugs!
Darley26
so i didn't manage to get any work done on the bike this weekend, as the weather was too nice out, but i am planning to the weekend coming, when i do i will give you all an update
The only thing that will cause the bikes limiter to engage is if you disconnect the speedo or you hit 180km/hDarley26 wrote:The symptoms of limited mode do sound very simialr to what i have but then so do the plugs, so i will try plugs as the first port of call, as you said, try the easiest one first.
Darley26
So thanks for all your help guys, I changed both the front and rear plugs, and hey presto - C'est magnifique
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
How old were the pluginses?
Darley26
About 2000 miles, and NGK, a known to be reputable brand, it now has denso plugs in it
krisztian_andre
Hmm, might want to look into the carbs if it happens again. Plugs should last longer than that.
