Speedo not working.
Phil_Norwich
Speedo not working.
Hi there.
The speedo on my bike has stopped working. I've read that it could be the drive unit by the sprocket rather than the cable. How do you the cable to see if its faulty or not?
Thanks in advance.
Phil.
Thanks in advance.
Phil.
- hannakournikova
Speedo not working.
Yea there is a nylon bush that attaches to the speedo drive at the sprocket end. It's pretty common for them to round off.
Disconnect the cable from the non sprocket end and I attached to and electric drill and pulled the trigger
- Deviant400
Re: Speedo not working.
or just disconect the speedo cable both ends you should be able to turn the inner with your fingers easily , remove the speedo drive from the sproket cover and check the white drive bush that attaches to the sproket nut is not fooked
http://www.davidsilverspares.co.uk/part ... mber_7785/
viewtopic.php?f=62&t=27307
Phil_Norwich
It was indeed fooked. The link you posted was the drive bush the other day, now its a needle setDeviant400 wrote: remove the speedo drive from the sproket cover and check the white drive bush that attaches to the sproket nut is not fooked
