RVF400 Neutral light problem
Andy_Edw
Post by Andy_Edw »
My neutral light on my nc35 flickers on & off when its in neutral, So i can't leave the bike running while on its stand because it thinks its in gear
Any suggestions?
Andy
Re: RVF400 Neutral light problem
clean the neutral switch connectors...
Andy_Edw
Post by Andy_Edw »
Where are they located?
err..down near the gearbox - right hand side if I remember ! Near the dipstick
Mavirick
Bike owned: NC35
Post by Mavirick »
Change the bulb
Andy_Edw
Post by Andy_Edw »
I checked all the wires, They were all fine
Can you even change the bulbs lol?
ibby4585
Bike owned: SP's
Post by ibby4585 »
You sure you got the right wire? It's a single spade end connectors thats really tight against wire easily to dislodge.
hannakournikova
Bike owned: NC30, NC35 & SP2
Post by hannakournikova »
Check clutch diode with working one. It's lhs sitting on the bike behind arse
magg
Bike owned: VFR400
Post by magg »
Check that neutral switch gives consistent ground signal by measuring its resistance to chassis with a multimeter while the engine is running.
