CDI ignition
james91
CDI ignition
Hey,
Just wondering whether anyone could tell me if one of those aftermarket digital CDI ignitions is worth getting....Do they improve low end and performance in general at all or do they just take away the 180kmh speed restriction?
Re: CDI ignition
I wouldn't touch them - there are various tales on this forum of users blowing their engines when using these cdi's.
I'd be very surprised if they did anything other than remove the 180 km/h restriction.
Re: CDI ignition
They are shit... leave well alone
Re: CDI ignition
3rd'd.CMSMJ1 wrote:They are shit... leave well alone
Pete Diggs
- Bike owned: NC35, Monster S4R, MG 850T
Re: CDI ignition
Which CDI Ignitions is he referring to? I want to make sure I stay away from them as well
Re: CDI ignition
There are many chinese copy ignitions with alleged 'HRC' map on them forsale on ebay and the like, with claims they improve power, no limit etc.Pete Diggs wrote:Which CDI Ignitions is he referring to? I want to make sure I stay away from them as well
They often have no rev limiter so easy to break engine.
The proper HRC ignition box wont' fit a standard loom as is designed to be used with the HRC kit (i.e cams / pistons / carb / porting etc)
For almost all cases the stock ignition box is fine.
Pete Diggs
Re: CDI ignition
Good to know. I know that the HRC parts are intended to work in sync together but I always assumed you could throw the HRC CDI on a stock bike and start from there.
Re: CDI ignition
On a NC35 you can, theres no kit engine parts for the 35 and the HRC CDI fits the stock loom.Pete Diggs wrote:Good to know. I know that the HRC parts are intended to work in sync together but I always assumed you could throw the HRC CDI on a stock bike and start from there.
On the NC30 theres 2 options, 1 is the SS/SP HRC setup which uses no kit engine parts, a stock CDI with HRC piggy back box of tricks to remove the stock restriction. 2nd option is the TT-F3 setup which uses many kit engine parts and a HRC CDI which only fits the HRC loom.
Pete Diggs
Re: CDI ignition
Thanks! That really clears it up for me. I appreciate it
