So what are these parts?
Akey
Hi All
Can anyone give me any heads up on where these parts fit on the bike? Would be eternally grateful!
- ibby4585
- Bike owned: SP's
Re: So what are these parts?
Could be wrong but without checking.
1. Is a bracket that fits on the horn/bottom yoke to keep the front hoses together.
2. Can't quite make out
3. Is another bracket that fits right side right at the bottom of the frame for a breather.
- ibby4585
- Bike owned: SP's
Ahh 2nd one might be a a choke cable bracket that fits on the rear left carb slide cover.
- iDemonix
- Bike owned: '92 NC30
Is the 2nd one one of the pieces that you put a bolt through it, then in to your engine casing, then you put a pipe next to it and bend that clip round it, so it holds the pipe around the engine casing? I might be talking bollocks, they're on the RH side of the engine iirc.
I have the 1st one sat in a draw, not fitted. Every time I see it I have to laugh as it looks like a pair of balls.
Le_Blur
- Bike owned: 1990 NC30
I think the second one secures part of the headlight sub-loom and bolts to the back of the clocks. Is the third one for removing boy scouts from girl guides?
