URGENT HELP "Cant Find Neutral"
Re: URGENT HELP "Cant Find Neutral"
Have you inspected the clutch basket?Mavirick wrote:thanks for the info the cluch is perfect i think its the cable ill have a look when i get homeslowsport wrote:hi, this probably isn't much help to you but i had the same problem when i first bought my NC35, in the end i replaced the clutch plates and had to smooth the clutch basket fingers as they had small wrinkles/wripples. since i had done this i can always select neutral easily
Common cause of the issue with neutral selection is a worn clutch basket.. while the plates and friction material might be good they can wear grooves into the fingers of the basket which prevents the clutch from fully enganging and disengaging properly.
If cable and gear rod are adjusted perfectly then this has been known to be the case on closer inspection, remedies for this are to either replace the clutch basket with a new one or to fill and file the basket smooth.
- Bike owned: NC35
Hi guys
I havnt inspected the cluch basket as yet sorry, work is keeping me very busy at the moment.
OK I’ve tested you theories and came up with the following (on the clutch lever) I cant adjust the screw its all the way out and still taking right at the end (finger tips)
If I adjust the screw in with just one rotation it takes all the way in the inside against the grip(around 10mm away) but then even with the clutch fully engaged, if you put the bike in first gear the bike moves forward(clutch all the way against the grip) go it is not fully disengaging.
I hope this makes sense
thanks MAV
thanks MAV
Then providing your cable isn't super stretched (have you adjusted the locknut end by the sprocket cover? Youll take out some slack then, just to check that it isn't cable stretch.
If it doesn't help i'd inspect the clutch basket next
- Bike owned: NC35
Hi guys
After a bit of faffing and fidling on the screws i can get neutral now by blipping the throttle just so slightly
is there a way of improving this.
I want to inspect the clutch basket next anyway is there something i need to look for that might stand out or is there a way of improving without doing a basket inpection
thanks mav
thanks mav
- JC120
- Bike owned: NC30 NC35 RC30 RC45 MC22 NXA
Did you ever get this figured out? I'm also having issues finding neutral on my NC30.
It's a common trait of these bikes, some might call it part of the bike's 'character'.JC120 wrote:Did you ever get this figured out? I'm also having issues finding neutral on my NC30.
Revving it slowly to 3000 revs or so and selecting neutral usually does the trick.
- JC120
Yes I read that on here a couple weeks back and have been trying that. Sometimes it will go in but most the time it still won't. I've been thinking of pulling out the clutch and inspecting the basket for any grooves worn in.
- Bike owned: Honda NC30
I had this prolem also just roll forward 2 cm and select while doing it
Goes in every time
Now ive changed my friction plates it goes into netrul 99% of time without having to roll forward or revin
Goes in every time
