IGNITECH CDI HELP!
brys
Bike owned: NC35 and track NC30
IGNITECH CDI HELP!
Post by brys »
Hi guys,
Back on here again! I need some help with connecting to my Ignitech CDI unit on my NC30. I have attached a picture of it, can you confirm what model it is just so I'm starting out with the right software? I have been using software versions TCIP4 v80 and v75 and both times I get the following message when I open the prgramme with the CDI connected:
'COM OPENING ERROR'
The CDI is connected via a USB to RS232 cable and the ignition is switched on giving the correct voltage to the unit. I have tried selecting the different com ports using the software but I still get the same message. Do you have any advice?
Thanks,
Ryan.
Re: IGNITECH CDI HELP!
Post by Neosophist »
USB -> RS232 can be touchey sometimes.
However, start with the simple, is the cable the right type? It looks like an extension cable to me..
There are two types of 9 pin cables.
A null modem and a straight wired (extension), while they have the same number of pins, they are wired differently inside.
brys
Post by brys »
hmm I did wonder that.. This is the one I bought.
http://www.ebay.co.uk/itm/230593067985? ... 970wt_1089
You think a 9 pin to 9 pin cable with a small USB to 9 pin adapter is better?
That's what I use, im sure here's a usb driver you need to download from there site
brys
Post by brys »
Looks like I better grab one and try that. cheers guys
porndoguk
Post by porndoguk »
You also need to make sure you set the correct com port on the tcip software, and also make sure bike ignition is on.
Looking in windows device manager to see what com port its on, the have to match
jimirobinson0
Bike owned: RVF400
Post by jimirobinson0 »
Also be aware it will only work with one version of the software not both. The ones with a gear shift indicator connection v80 those without v75 (from memory) happy to help if needed.
brys
Post by brys »
cheers just bought a new 232 cable so gonna give it a go with that. I'll let you know how it goes!
brys
Post by brys »
Hi guys,
Managed to get connected to my CDI now it was the cable in the end! Thought I would add a copy of the map that is on there now. Any thoughts appreciated! Going to dyno on sat and see how its running, changed my induction system back to standard with #35 pilot jets 2.25 turns out on the screws with HRC needles and 120 jets front and 122 Rear. Fingers crossed!
petrolhead19
Bike owned: 2 x nc23's 1 x nc29
Post by petrolhead19 »
brys wrote:cheers just bought a new 232 cable so gonna give it a go with that. I'll let you know how it goes!
Do you have a link to the cable you ended up getting in the end?
