G-Force in Cycle World Article
- RickOliver
Re: G-Force in Cycle World Article
I thought they all evolved around you, Mike....
magg
- Bike owned: VFR400
A quick question if I may Mike, are you still using nikasil plated cylinders. The info on your web site suggestion you have gone bask to bore OEM liners.
g-force performance
- Bike owned: VTR-250, VFR400RR,
They Yamaha Rings are Chrome Plated and prefer to run against the cast-iron. We were seeing micro-welding on the ring faces against the NikaSil. So, we did indeed go back to the cast-iron, OEM liners. Also, at 57mm, we were not having any issues with boring through, like what occurs in the 58mm bores.magg wrote:A quick question if I may Mike, are you still using nikasil plated cylinders. The info on your web site suggestion you have gone bask to bore OEM liners.
Mike Norman
G-Force Engine Development
