Cleaning those crappy sections
Mavirick
Bike owned: NC35
Post by Mavirick »
Hi there
after a few years of having my bike i`ve decided to rebuild the 35 completely (build thread to come)
what do you guys use to clean those hard to reach places and stubborn grime expecially on the motor and the inside front of the frame
Ive tries clean green (worked so so)
petrol (expensive but works really well but even then there ate these sections that just don't get clean
another question whats the best way to polish the headers and the frame and swing arm to get the best results
thanks MAV
ibby4585
Bike owned: SP's
Re: Cleaning those crappy sections
Post by ibby4585 »
Gunk is brilliant but expensive. Get yourself a small garden pump spray and fill it with parafin then get some brushes, plastic ones and brass wire ones and shit loads of rags!!
Enjoy!!
Mavirick
Bike owned: NC35
Post by Mavirick »
Does pariafin really work that well
ibby4585
Bike owned: SP's
Post by ibby4585 »
It's the cheapest. Gunk is the best I find, maybe do 50/50 mix to cut the cost.
lizard821000
Post by lizard821000 »
yup, no easy way im afraid, just takes time and effort, worth it though. i couldnt believe how much shit come off mine.
if your polishing the frame for a mirror finish you ll need wet n dry through the grades and some compound on a wheel to speed things up, autosole is always a winner too! if its the brushed look your keeping , i found fine wire wool worked wonders.
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
SOC by rock oil is pretty good too its a tad cheaper than gunk , well it is at my local shop anyway,
personally i wouldnt mirror polish frame and swinger , it looks really good but you'll really need to keep on top of it to keep it that way
Deviants AM/PM build
viewtopic.php?f=62&t=27307
Vfr400/tbird
Bike owned: VFR400 NC21 Thunderbird 900
Post by Vfr400/tbird »
Might sound strange but to achieve a polished frame on my Nc21 i used a fine grit wet/dry sand paper and autosul together at the same time i found that once it went through the lacquer it went real shiney real quick 8-)
Its not a method i'd heard before but tried it and it works, i never used a wheel or any special compound just autosul and wet n dry about 6 quid's worth in total!
porndoguk
Post by porndoguk »
Brake cleaner, parafin,
And the best but be carefull it doesnt go near plastic, powder coat and paint = carb cleaner
