Where posts and threads can be moved to future safe keeping.
Locked
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
thought so. i will try with a breaker bar soon.
xivlia
Post by xivlia »
okay, the breaker bar didnt do the job... this thing is truly jammed in.... the gears will move and jitter even though its on 6th gear, the brakes pressed on hard.... used a cloth as well.... no use.... they just jitter about.
Which nut are you removing? The clutch nut?
You'll need to shock it - air gun, impact driver or similar. Or even more leverage....
xivlia
Post by xivlia »
yeah the clutch nut, the one in the middle. dont have impact driver or air gun etc. anyway i can lock the gears in place?
magg
Bike owned: VFR400
Post by magg »
Thought you were removing the starter clutch?
xivlia wrote: anyway i can lock the gears in place?
Yes a ratchet strap or some tough denim like i first told you, if the gears are moving then what your using clearly isnt doing the job.
porndoguk
Post by porndoguk »
Get an old pair of leather gloves and use one of the fingers in the teeth
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
personally id be putting the person who sold you the bikes fingers in the gears
Deviants AM/PM build
viewtopic.php?f=62&t=27307
magg
Bike owned: VFR400
Post by magg »
Would be interested in clarification of which BOLT he is trying to undo.
Post by Neosophist »
Not an NC30 engine but the starter clutch is very similar.
This is what your undoing right?
Locked
