NC35 Headset Bearings
rockomsockomrobots
Hey Fella's
I think i have done my headset bearings, im getting some horrible clunking noises under the front brakes and can feel it move over a bump and can feel a bit of play in the headset while turning at low speeds. I have it booked in to get fixed in a week.
Would it still be safe to limp it by until then?
Mike
Mike
- skinnydog0_0
- Bike owned: Penny Farthing
Re: NC35 Headset Bearings
Well you could try tightning teh headstock nut to eliminate some of the play, but if it's bad i would get the bus/train. Not nice trying to turn and finding your steering is stuck
rockomsockomrobots
Hey Guys,
How hard is it to replace the headset bearings myself?
I have the Haynes manual handy.
Mike
Mike
It is easy enough - same as doing them on a pushbike..but you need to get he bike stable and either jack it under the pipes or dangle it from the ceiling.
- skinnydog0_0
CMSMJ1 wrote:It is easy enough - same as doing them on a pushbike..but you need to get he bike stable and either jack it under the pipes or dangle it from the ceiling.
It is also very useful to use the old bearing as protection when driving the new bearing onto the steering stem
