Carbon swing arm cover
I bought a carbon swing arm
I have just tried to place it on the bike and the exhaust was in the way has anyone fitted one of these, as I'm sure if I need to or even where to remove the exhaust to have access to the swing arm.
Many thanks Pete
Many thanks Pete
- Deviant400
Re: Carbon swing arm cover
i have one but fitted mine before i put the exhaust on the bike, you should be able to plop that on with the exhaust in place i would of thought , but if you cant get good access you might have to remove the endcan to get a bit more access failing that the whole rear section of the pipe ,i used normal clear silicon sealer and held it on tight with some electrical tape till it set , looks nice on a black swingarm
viewtopic.php?f=62&t=27307
Being remove back half of exhaust tomorrow then.
Is the back half joined underneath and the rear cylinder head?
Many thanks Pete
Many thanks Pete
Depends on the exhaust you got fitted, some half systems run pretty close to the swingarm namely yammamoto making it hard to get it on without rubbing
Do you know where it would say what make system it is or any way to identify what it is
Many thanks pete
Many thanks pete
Stick a pic up of it but if your system is running close to the swingarm then its not gunna fit without rubbing, you could try loosening off the system and retighten it trying to get it to give more clearance but some system just sit close and theres nowt you can do about it
I have one with a yamamoto and have no problems with it rubbing.
Attatched it using double sided tape for a bit of safety that pads it out slightly and still fits fine.
I havent had time to get the fairing off it yet but here's my clearance
And here is a few quick pics of the system I could take
I will take some better ones when I get my fairings off
Farkin hell that poor bike needs a clean,
Yh she not long got cleaned I will be cleaning with all fairing off and a tooth bush Monday :)
