Electric testing
V4WTF
Re: Electric testing
Shouldn't it be able to run fine without the battery once started? Does this confirm an alternator issue?
magg
- Bike owned: VFR400
Rotor should be locked to crankshaft by matching taper, you should need a puller to remove. Engine will not run without battery, the rect/reg will charge a battery but not run the engine on its own.
Alternator output voltage should be checked without the rect/reg connected, should get approx 50 V AC at 5000 rpm.
- bikemonkey
Right so I'm in the garage after work, and testing the alternator output.
After having to clean off the spark plugs because the engine wasn't starting I managed to get some voltage readings.
Had my dad hold the bike at 5K revs and I tested the three yellow wires of the reg/rec plug and got no readings from any of them (0 volts).
The left pin (red and yellow wire) was reading 12.4 volts and the right pin (green wire) wasn't reading anything either.
I'm guessing this means my alternator's fudged? Or is it something else?
magg
Yellow wires are AC volts and you measure from one yellow wire to another yellow, what was your multimeter setting.
Red/yellow wire is battery voltage and green wire is earth therefore your readings for these wires is ok.
- bikemonkey
Now here's where I've been an idiot. (should have payed more attention in my electronics class when I was at school)magg wrote:Yellow wires are AC volts and you measure from one yellow wire to another yellow, what was your multimeter setting.
Had the multimeter on DC volts and tested each yellow wire to earth like a muppet. Shall get back on it soon.
magg
No problem, easy to forget when one small part of the electrics is AC.
- bikemonkey
Right so tested it properly this time.
Got about 42-44 volts between each of the yellow wires at around 5K revs.
hardnutdvd
- Bike owned: RVF400 NC35
edit.. replying to wrong post .. oops
- bikemonkey
The rec/reg plugs back in, but it doesn't click, it just kinda slides in then wont go any further.
I had taken readings off the battery running and not, they were both around 12 volts.
- bikemonkey
haha oh wellhardnutdvd wrote:edit.. replying to wrong post .. oops
