RVF 400 Fan Switch
chuchu20
RVF 400 Fan Switch
Post by chuchu20 »
Hey guys
Does anyone know how to put a fan switch on an RVF 400? Done it once before on a cbr250, just connect the fan switch to ground. Cant seem to find out how to do it on the RVF. Thanks
phil x
Bike owned: 2 x 650 Transalp's, '90 nc30
Re: RVF 400 Fan Switch
Post by phil x »
Yep, the fan is permanently live (off the ignition), use a switch to earth & complete the circuit.
Phil
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
Fit a fully insulated piggy back spade terminal to save cutting into the existing wiring.
chuchu20
Post by chuchu20 »
Where did you mount the spade connector too? Is it to the bit the hangs off the left of the bottem rad? The fan switch I think it's called?
arsey30
Post by arsey30 »
The green wire goes to one side of the new manual switch and the piggy back spade pushed onto the existing rad fan switch.
The original fan switch wire spade [black shrouded] pushes onto the piggy back connector.
The wires are hanging off in the picture to show more clearly their fitting, picture is new spade removed from rad fan switch.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
dont cut the red wire
chuchu20
Post by chuchu20 »
All good got it all to work tonight thanks
