Front wheel knocking,, what can it be?
DK-Tandy
- Bike owned: CBR400RR NC23
I had a knocking on the front wheel a few weeks ago, so i replaced front spindle and front wheel bearings, and the knocking went for a days, and its came back, im going to check whether its wheel bearings again tomorrow, if not, what else could it be?
also, im on the 4th set of bearings in the front since owning the bike,, does my wheel like to eat bearings??
kiwi racer
- Bike owned: CBRs
Re: Front wheel knocking,, what can it be?
Can you assure us that the front wheel has a bearing spreader tube between the bearings ???
- Deviant400
viewtopic.php?f=62&t=27307
tanuki
headstock?
DK-Tandy
yeah, that spacer is there :) makes removing the bearings a pain as you need to knock the spacer around to be able to hit the bearing..
it only clicks on certain points and i noticed tonight, it doesnt always click, only occasionally..
- CRM
Cheap bearings from ebay by chance ?
- thunderace
- Bike owned: R6, YZF600R
Perhaps your front wheel doesn't know where to come in
sorry, old drummer's joke
DK-Tandy
wemoto bearings.
- Davez29
- Bike owned: NC29 forever
I suppose it depends when it knocking, best get it up at the front and do the usual checks pulling the wheel at 1/8th turns at a time for any bearing play, then try moving the forks and looking for play at the headstock and also check your calipers, maybe something there. Finally check in case you have worn fork bushings or even a slightly bent fork leg, if it happens when your braking especially. Dont discount something else loose giving the impression of knocking somewhere else.
DK-Tandy
the knocking stops under braking, whether it stupidly light braking or heavy braking
