Thundercat forks in a 3en2
SteveO916
- Bike owned: Ducati 916, GSXR750, XR400R
Hi,
i'm thinking of putting thundercat forks in my 3en2 as i know they will fit straight in, but can i (hopefully) use the fzr wheel and spacers (or get spacers made)?
anyone know? anyone done it?
Taggyd
Re: Thundercat forks in a 3en2
sure kayla can do you some spacers if they dont fit!
- thunderace
- Bike owned: R6, YZF600R
I think you'll need to swap the yokes over too. I'm sure the Thundercat forks are bigger diameter.
The forks are 41 dia so they'll fit in the yokes but you'll need the front wheel etc because the spindle is a larger dia. That might be an issue if the yokes have a different fork spacing.
You could look for a front T'Cat end, and it should drop straight in but you could also look for a YZF750R front end because it's lighter.
- Kayla850
- Bike owned: Sunn Tzar S2
The forks will fit in the yokes fine, but the FZR wheel uses a 15mm bearing and the Thundercat forks use a 17mm spindle. It's doable but I;m too drunk on g&t to answer properly now!SteveO916 wrote:Hi,
www.projection-racing.com
www.pjcfasteners.com
uniquefzrfreak
- Bike owned: Harley Sportster 883
Get the T'Cat front wheel and discs etc. around 80 to 100 pounds, often with a good tyre, online.
Makes for an easy swap!
