Front wheel knocking,, what can it be?
DK-Tandy
Bike owned: CBR400RR NC23
Post by DK-Tandy »
I had a knocking on the front wheel a few weeks ago, so i replaced front spindle and front wheel bearings, and the knocking went for a days, and its came back, im going to check whether its wheel bearings again tomorrow, if not, what else could it be?
also, im on the 4th set of bearings in the front since owning the bike,, does my wheel like to eat bearings??
kiwi racer
Bike owned: CBRs
Re: Front wheel knocking,, what can it be?
Post by kiwi racer »
Can you assure us that the front wheel has a bearing spreader tube between the bearings ???
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
:plus: yeah there should be a spacer between the bearings in the wheel, this stops you over tightning the wheel and deforming the bearings , without it the bearings wont last 5 mins
Deviants AM/PM build
viewtopic.php?f=62&t=27307
tanuki
Post by tanuki »
headstock?
DK-Tandy
Post by DK-Tandy »
yeah, that spacer is there :) makes removing the bearings a pain as you need to knock the spacer around to be able to hit the bearing..
it only clicks on certain points and i noticed tonight, it doesnt always click, only occasionally..
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Cheap bearings from ebay by chance ?
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
Perhaps your front wheel doesn't know where to come in :lol:
sorry, old drummer's joke
DK-Tandy
Post by DK-Tandy »
wemoto bearings.
Davez29
Bike owned: NC29 forever
Post by Davez29 »
I suppose it depends when it knocking, best get it up at the front and do the usual checks pulling the wheel at 1/8th turns at a time for any bearing play, then try moving the forks and looking for play at the headstock and also check your calipers, maybe something there. Finally check in case you have worn fork bushings or even a slightly bent fork leg, if it happens when your braking especially. Dont discount something else loose giving the impression of knocking somewhere else.
DK-Tandy
Post by DK-Tandy »
the knocking stops under braking, whether it stupidly light braking or heavy braking
