Did This Come Off My Bike?
Woddy
Bike owned: FZR 400 RR SP
Post by Woddy »
While adjusting the chain slack on the bike today after fitting a new rear sprocket and a general check over, I could hear what seemed to be this part fall to the floor from the bike, unless it was already on the floor which I am almost certain that it wasn't. I have looked high and low to see where this may have come from and have found nothing, I don't really want to ride the bike on the track untill i am sure what it is. Hopefully it has nothing to do with the bike :? ? It is about 1 and a half inches in length with a flat head adjuster on the same side as the thread..
Deviant400
Bike owned: NC30, Kona Cowan
Re: Did This Come Off My Bike?
Post by Deviant400 »
rear brake pad pin maybe ??
Deviants AM/PM build
viewtopic.php?f=62&t=27307
alexwitham
Bike owned: 675R, GSXR6, NC30
Post by alexwitham »
Thats a good shout.
Woddy
Post by Woddy »
Deviant400 wrote:rear brake pad pin maybe ??
Thanks for reply, the brakes were the first thing i checked!!
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Post by Taggyd »
rear pins are a lot thinner after the thread,just replacedmine! take a look at the genny cover they have a slotted screw head in there i think, looks about the same size.
Woddy
Post by Woddy »
Taggy, there are no screws missing on the genny cover, i think i know the screw you mean though and that is still there!!
Taggyd
Post by Taggyd »
have you checked the shock and all the bits attached to it?
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
That 'screw' looks to be made from alloy rather than steel :?:
Taggyd
Post by Taggyd »
it's not the adjuster at the bottom of the forks is it?
Post by Evilchicken0 »
I'm trying to think of a flat head screw, all I could remember was the clutch adjuster in the sproket cover ... but I think that's a phillips
