Wieght reduction
fastdruid
Re: Wieght reduction
Well apart from the Ohlins.RonniB wrote:Rallykays post is great by the way, if it only tell you one thing, then let it be that Nitron makes the lightest aftermarked shocks availeble.
DruidRear shock absorber Hyperpro 3600
Rear shock absorber Ohlins from a GSXR thou 3210
Rear shock absorber Aprilia RS250 3200
Rear shock absorber 3052
Rear shock absorber Nitron sport 2300
Rear shock absorber Ohlins 2000
venom51
Mines already at 150kg with 1 gallon of fuel on board. fuel tank scheduled to be done this winter.
adam24
ken/venom, are u putting a cabon fuel tank or what ?
venom51
I am going to have a 1.5 gallon cell fabricated in the same shape as the rear of the tank now and then either a fiberglass or carbon shall to make it look like a stock tank.
RonniB
@ fastdruid, yes I know its on the list, but its doubtfull where the info is from, since no one seem to have a 2000gr øhlins shock, and Kays new øhlins shock was a heavy bugger. The Nitron on the other hand is as close to "over the counter" as you get and the weight figure is verified.
Much of the weight is in the spring, the good (highly dense) springsteel used in aftermarked shocks is far heavier than the cheaper ones on standard shocks.
Spring type also affects weight, my hyperpro shock went from 3600gr to 3420gr when I had the progressive spring swapped for a linear one, because fewer windings is needed on a linear spring. This was just an added bonus, the change was due to me not liking the progressive springs feel.
@ Venom51, the fuel cell sounds interesting, please give updates when you make any progress.
fastdruid
I know my ohlins (for the SV) is a lot lighter than the GSXR750 item it replaced (which in turn was lighter than the original). I'm not getting it out just to weigh it though! :D
Druid
Druid
- fourfingers
- Bike owned: NC30RK,NC35RR
From the list: Nitron Sport-300gr= Rear shock absorber Ohlins 2000
I will never go for an öhlins, anyway
Should have read the second page lol ...
- RickOliver
The Nitron Sport shock is light because it`s the base model without a remote reservoir - the Nitron Track shock would be a more direct comparison with the Ohlins.
(Sorry, no I can`t tell you what it weighs...!)
