slow revs drop
richieps13
slow revs drop
Post by richieps13 »
hi all, new to this site and new to motorbikes. ive just bought a vfr nc21, and everytime i give the engine a little rev, they seem to take a while to drop back to idle. does anybody know what the fault could be. cheers
Re: slow revs drop
Loose inlet rubbers maybe
richieps13
Re: slow revs drop
Drunkn Munky wrote:Loose inlet rubbers maybe
i did try tightening the clips on them, got a few turns but nothing major. is there any way i can test? wd40 sprayed at rubbers etc?
Re: slow revs drop
Spray easy start aroud the rubbers with the engine running to see if the revs rise but bear in mind that if the easy start is sucked up through the airbox then the revs will rise regardless.
Its not going to hurt hetting the carbs off and checking them and making sure the inlet rubber clips are seated right also.
cbr400rrn
Bike owned: NC29 CBR600F
Re: slow revs drop
Post by cbr400rrn »
Has your handle bar grip worked its way loose and catching on the bar end weight?
Have a look, its a fix that will cost you nothing before you look elsewhere
lizard821000
Re: slow revs drop
Post by lizard821000 »
normally a sign of a lean pilot or as said, snagged throttle or air leak. check all .
