QUIICKSHIFTER
Re: QUIICKSHIFTER
Well all the unit does is kill the ignition for a split second .2strokepowerhouse wrote:can you use the dynojet push type quickshifter and wire it in some how or do you need to have one of these "power commanders"
I seen something before about wiring a shifter to the coils but not sure what that set up but will see if I can find some info on it .I think alot of the purpose of the wee box is gauge the time the ignition is cut ,
I will try and get some more info for you
Re: QUIICKSHIFTER
You can wire it into the side stand cut out - it will cut the engine for a split second and then carry on.
Re: QUIICKSHIFTER
I have a box coming that works that way ,through the side stand switch ,think there is a few different wires on it with different timing's ..Just need to get a quickshifter now..Evilchicken0 wrote:You can wire it into the side stand cut out - it will cut the engine for a split second and then carry on.
Could be a bit more head bashing done getting that sorted....lol
Re: QUIICKSHIFTER
Should be staight forward enough
- Bike owned: 3TJ1,3TJ2,3TJ6,900ss
Re: QUIICKSHIFTER
cheers for the info guys il have a look into this way of doing it
