Rear manifold
Rear manifold
Seeing as alot of aftermarket systems still use the standard and restrictive rear manifold I wondered if anyone has looked into getting an aftermarket version made up?
Would it be worth the hassle and is there really much to be gained from doing it?
Re: Rear manifold
Any opinions?
- royster81
Re: Rear manifold
apart from the weight saving i don't thing there would be much exhaust gas flow to be gained after all they are two lenghts of straight pipe, but they weight a ton so a lighter version would be good but the costs would probably be crippling
