Show me your dampers?
Spike16
Re: Show me your dampers?
hey im not worried about it working! im worried about it looking good!!!
nah since fitting mine 3 days ago iv had 3 hairy fish tail moments in the rain and the bike just straighted itself strait away and ment i could get strait back on the power (not that im that quick on the road)
- DAC
- Bike owned: 89 NC30
[quote
[/quote]
I notice that you have an oval Daytona Steering Damper fitted. Have you tried to service it with one of these kits?
http://www.1tail.com/sa/c/Steering_Dampers.htm" onclick="window.open(this.href);return false;
DAYTONA ROUND STEERING STABILIZER REPAIR KIT Item #: 17-053
My damper feels a bit rough when the adjustment knob is turned up past halfway. Also, should there be any defined clicks, or is it a smooth rotary adjustment?
Regards,
Dave.
[/quote]I notice that you have an oval Daytona Steering Damper fitted. Have you tried to service it with one of these kits?
Regards,
Dave.
RWB NC30
- RVFHooligan
Dave, no need to service it yet, it was brand new, and yes it's a Daytona kit. I think mine has defined clicks, not sure I haven't set it up and haven't ridden the bike yet. I'll check for you later.
I've had several daytonas, they've all clicked throughout their adjustment range.DAC wrote:[quote
[img] damper feels a bit rough when the adjustment knob is turned up past halfway. Also, should there be any defined clicks, or is it a smooth rotary adjustment?
- DAC
Thanks, I thought so. I'm a bit concerned that the shaft may get knocked and its setting altered accidentally.I've had several daytonas, they've all clicked throughout their adjustment range.
Regards,
Dave.
RWB NC30
- spooky
- Bike owned: nc24
Hey you, cheeky. Like you say its still a wee v four.hannakournikova wrote:then again spooky you dont need any bigger, its ONLY a nc24 you have<snigger> OJ :D
Spike16
was just watching moto gp 125 and as they pulled up there was a great shot of smiths and espagaro's steering dampers, smiths was mounted like rvf's and espagaro's was mounted like mine so it obviously makes no differance o and its nice 2 see a part on my bike being the same as a part on a 125 gp bike :D
RVF007
ah thought Ill through my couch damper (sprint) in here... been taken off the bike and fitted to the couch :D it will be goin back soon... had a near mis the other day, recon if it was on it could have been a bit more forgiving
- RVFHooligan
Dang, for a minute there I thought it said crotch damper!?!?!?!?RVF007 wrote:ah thought Ill through my couch damper (sprint) in here... been taken off the bike and fitted to the couch :D it will be goin back soon... had a near mis the other day, recon if it was on it could have been a bit more forgiving![]()
I like your mount better on the damper body because you have a heim ball joint built into it which keeps it closer to the frame. I had to use a 8mm male heim joint threaded through the mount on mine so it sticks out a 1/2 inch or more.
RVF007
lol...crotch damper for them unstable fly day's.
